Just installed a TGlide 1.25 lift & Tour Box Lift. Didn't get a chance to ride my Triglide yet. But wanted to make sure that anybody planning on doing this, take the instructions re "factory known to use copious amounts of Loctite at times" serious. The only way I could remove the 9/16" axle flange bolts, was with strait (no offset at ends), 12" long, boxed end wrench. It took so much pulling power to break loose the bolts, that any offset in a wrench (including a ratchet wrench) caused the wrench to slip off of the bolt head. Everything went smooth per the instructions (except the factory loctite part). Hope this helps somebody.
