TG Trunk Lite Kit
Anyone install a HD trunk lite kit in there TG?
Feedback on install, operation etc please.
Thx In advance..HB
Yep. First thing I did to my FLHXXX. Easy install; just follow the directions exactly. Works great, gives more light in the box than expected. Only thing necessary to remove is the seat (but darn, ya gotta do that for most any accessory install it seems LOL) for access to the wires. Disconnect the battery though, just to make sure you don't accidently flash the smoke out. Well worth the money. :10:
I have a 2015 trike. When i went to install the light kit it went in easy. It has a harness that tells you to run to the battery but I had a open plug when I opened up the rear door panel. It works great by just plugging it in but I was curious if anyone knows if I should still run the harness that was with the kit
trunk light
I installed it in my trike. Installation was easy. I also got lucky and found a accessory plug on the door so did not have to run the wire to the fuse block. Ito seemed easy to install the wire however
Roger71!!
