TBW connection
Rogue1
400+ Posts
Oct 8, 2018
581
620
Ramseur, NC
Dale
I'm putting new bars on the Tri Glide and I'm trying to hook up the throttle by wire connections. I got one hooked up but I'll be damned if I can find where the other one goes. It's a two wire connection I believe they're black and white. I can't find anywhere where they will connect. Does anybody know?
OK. My bad. I think that's the heated grip plug in. Why it comes off the TBW wires I don't know
Do you have heated grips?
Does it look like this
I believe the black and white wires are for heated grips
Those wires are for heated grips. If don't have them then won't use it. If you do install heated grips then the right grip plugs into the end of the twist grip sensor. Pretty neat setup and works well for heated grips.
zigzag3227
