After putting on comfort lift kit and mounting low profile led taillights there is a lot of daylight between top of tire and fender . Can you run a taller tire without having to change speedo .
The taller tires will affect your gear ratios making everything higher/taller geared. You may not like it, I know I would not like it. You will loose over all power through your gear range. I feel the Freewheeler from the factory is already geared tall enough and performs well, again would not want the gearing taller.
Ride Safe,
Bill G
Strange how people think the gearing on the FW and TG is either too tall or too short. Most seem to think it's too short. I think you're the first FW owner that thinks its gearing is too tall. The 2009-10 TG's were geared 32/70 and most owners complained that 6th gear was too tall. So,H-D lowered the gearing to 30/70 and most owners think engine rpm in 6th is a little excessive. :Shrug:
Our trike is geared 32/68 so you probably wouldn't like it either,Bill.![]()
Clint,
I said the Freewheeler from the factory is already geared tall enough and performs well (let me clarify more clearly, I like the gearing as is stock). I never said or meant to say it was to tall, sorry you got that out of what I said. I did say that I thought taller tires in the rear would make or possibly make the gearing to tall and stated I would not care for that myself.
Take Care Friend & Ride Safe,
Bill G
Getting to the other part of that post...the rear comfort lift. I take it from what you are saying the TG and the FW are different heights from the factory? I thought they were pretty much engineered the same in that regard. I though the Free Wheeler was built on the same under frame as the Tri Glide. I'm sure they both use the same size tires. The wheels look different, but I'm pretty sure they are the same size and are interchangeable between the two models.
What I'm getting at, is the lift shouldn't make the FW any taller than it would the TG. Am I wrong?
I was thinking about finding out how many teeth on the front pulley of final drive . I know on my softail build I went from *a 24 to a 23 tooth sprocket for the final drive . I wonder if this change would help to offset taller tire size??
