stuck starter
My starter is stuck on even with key off.I think it"s my starter relay.Dose anyone know where it is.:confused:
On my ride it's on the left side under cover.
Follow the positive cable from the Battery back. Should lead to a canister style relay.
Also would be a good idea to put what ride you have.
EZ, if it is a GL1800, it should be behind the battery box on the left side. The starter relay and reverse relay are both located there. Might depend on the year of bike. Had a friend of mine's trike do that, replaced both relays while he was in there, fixed the problem. Good Luck! Jay A.
Sparky64
Sparky64
