Strange rear brake problem is Solved on 2018 GW CSC DCT
paid4c4
300+ Posts
Mar 28, 2016
320
309
Crestview Hills, KY
Bill
My rear brake pedal was mush and had to be pumped several times for the pedal to get hard and effectively operate the brakes. This most certainly sounded like a typical need to bleed the brakes to expel air from the system.
I took my GW to my independent mechanic who was a Honda Red Tech for years before opening his own garage. He agreed that a good bleeding was needed. He bleed the brakes and bleed the brakes and the pedal got no better. A thorough brake system inspection revealed no leaks or other problems.
I placed a call to Will at CSC to discuss my problem. Will was very helpful and as soon as I described the problem he said "stop go no further." I thought OK he sounds really sure he knows the fix to my problem. Will then explained that CSC had a number of brake calipers which were assembled with old grease. When left unused it causes the pistons to become stuck or sticky in the caliper bores. He said to remove the pads from the calipers and pump the brake pedal until the pistons traveled out of their bores and touched the rotors. I passed this on to my tech and we both had a good chuckle.
About an hour later I got a text from my tech who said "I've learned something today!" The strange fix Will passed along worked and worked well. Bottom line I now have great rears brakes. I must confess that Randy aka Papa Zook told me so! Please don't tell him I admitted he was right and I was less right. I thought this might someone else with a similar brake issue.
Bill
CSC Sport (GL1500) no rear brakes
I'm wondering if I have the same problem. My bike sat for about 6 months unmoved until recently. When I finally got it out I had no rear brakes and basically no rear brake pedal. I don't see any leaks under the bike where the brake fluid might of leaked out; however, it was low. I'll check this out. Thanks!
Mine has been back to the dealer two times for a mushy brake pedal. At one point we even took the rear calipers off put a block of wood in the pads and bleed them with the bleeders pointing up. No better but got a lot of "orange stuff" out of both sides?? Brakes are still not optimal but seem to be working so I'm riding it. Will try this and see if it's a solution,... thanks for the post.
Bill
I had the same problem, did the same thing you did. Same issue as you. Called Will, gave me the same advice as he gave you about the pistons. But, I did the same thing and nothing got better. I'm stuck.
For those having this issue, I suggest that you do this test. With your trike turned off and the park brake off and sitting on a level surface, give your trike a gentle push and see if it rolls freely. If it doesn't that is a sign that the rear brake calipers may be sticking and need the above fix performed.
Hydraulic brake systems have never played good with foreign materials ( too much assembly lube, moisture, wrong type of brake fluid) ETC
This is why regular maintenance and up to date info like Randy has given here is a MUST read for everyone
I always tell my customers, it does not so much matter how your bike runs, it better stop good and every time or very bad JU JU comes your way JMHO
Read this post with great interest as I also have a mushy rear brake pedal on my CSC trike. I asked Will about it when my trike was back at the factory for other issues, but he said it felt pretty good. Still feels mushy to me though although the trike stops well enough.
Question: If one pushes the pistons all the way out, does that not result in brake fluid all over the caliper or am I missing something? I have never rebuilt a caliper, so I am clueless to what happens when the pistons are popped out,
but it seems to me like this would purge the system, at least that caliper, of brake fluid.
dadztoy
dadztoy
If you do it on the bike be prepared to have fluid come out as the piston/ pistons come out
If you remove the caliper from the bike you can let most of the fluid drain out of the hose mount, then use compressed air to pop the pistons out, be careful and wear eye protection
With this procedure, which CSC researched and developed to solve the soft brake issue, you do not remove the brake lines, bleed the brakes before or after the procedure or do any anything that causes any loss of brake fluid. You are simply removing the brake pads, pumping the rear brake pedal until the pistons are fully extended against the rotors, then compressing the 4 brake caliper pistons until they are fully 100% retracted, then reinstalling the pads.
I have done this on two Goldwing DCT Encore trikes I built and it cured the soft brakes on both. The pistons will resist being fully retracted and make you think they will not seat, but they will. I used a large flat blade screwdriver to pry them into fully retracted position.
With this procedure which CSC developed to some the soft brake issue, you do not remove the brake lines, bleed the brakes before or after the procedure or do any anything that causes any loss of brake fluid. You are simply dismounting the caliper, removing the brake pads, compressing the 4 brake caliper pistons until they are fully 100% retracted, then reinstalling the pads and remounting the calipers.
Very good info, I clean the pistons as good as possible before pushing them in so as not to let any debris follow them in
It can be a tedious chore on some calipers, but if done will help improve braking also
If you are careful you can roll down the protective outer piston dust shield exposing the piston, you can then clean debris before pushing pistons in
Yes, giving them a wipe down is a good idea, but these are mounted up top directly above the disc and in such a way that you will likely find little if any debris on the pistons. They are enclosed within the rear trike body fender well and are pretty well protected from the elements.
With this procedure, which CSC researched and developed to solve the soft brake issue, you do not remove the brake lines, bleed the brakes before or after the procedure or do any anything that causes any loss of brake fluid. You are simply dismounting the caliper, removing the brake pads, compressing the 4 brake caliper pistons until they are fully 100% retracted, then reinstalling the pads and remounting the calipers.
Really? That's it? I gotta get this done, hopefully they can fix the DCT shifting issue at the same time.
Good idea.. I tried it but the brake pedal still needs to be pumped. Any other suggestions?
OK, just back from the dealer after having the rear brake issue and shifting problems addressed. The tech did the procedure as outlined above and now the rear brake pedal is firm with great feedback and working as it should.
He also installed the new module supplied by CSC and the trike shifts like a champ in all modes, whether shifting manually or letting the trans shift itself. Outstanding! Great job by Nault's, always take great care of me. Thanks also to Zook for all the great info :clapping:
Yes, this fix does work for the issue described by CSC, and that is the grease issue.
One thing to note is that the ABS brake system on these new '18 & newer Honda Goldwings, is that this brake system is designed to utilize BOTH the front and rear brake working in unison at the same time, so do not expect to get optimal braking when using just the rear brakes alone, because you will not get sufficient braking when using just the rear brakes. You MUST use both the front and rear brakes simultaneously.
Did your dealer re-initialize the transmission after he installed the CSC shift module? This also makes for a BIG change in the way it shifts.
Did your dealer re-initialize the bike after he installed the CSC shift module?
Not sure, it was 41 degrees on the way home, seemed to shift a little "crisp" but I was leaning on it pretty hard so I really couldn't say for sure. It was not stated on the repair order that he did but I know he has done it before and so have I. Next time I ride it and get it sufficiently warmed up I will initialize it, that always makes a nice difference in how the bike shifts. Seems like need to do this every 2K to 3K miles or so.
OK, rode the trike to work this morning (23 degrees when I left the house). Stopped for gas after about 20 miles and 3 bars on the temp gauge. Initialized the trans and rode to work with the DCT as smooth as silk. Looking forward to a nice (hopefully warmer)ride home later.
mushy brake pedal
I had a mushy brake pedal on my 07 street glide trike. I got a new distribution block build (up behind the battery ) and I used the fitting Harley has on the front calliper(noticed it on my buddies 09)that has a banjo fitting and a bleeder fitting as one piece. I also replaced the cartridge in the pedal. Blead the system down and now I have a solid pedal. Its still winter up here so I haven't ridden it yet but I know the the pedal is way different than before. This Harley doesn't have ABS brakes by the way.
I can attest that the brakes work fantastic particularly if you need to really brake hard-as Papa Zook mentions you MUST use BOTH FRONT & REAR BRAKES. The 2018 GW DCT Tour prior to the CSC conversion would have no issues on stopping when you clamped down on the front brake w/out using the rear brake pedal. But with the added weight of the trike kit if Ya really need to make a sudden Stop use BOTH front & rear brakes.
Brake
As a rule I would say I use my front brake pressure more than my back brakes but I do use them both to stop even when the is not an emergency.
Aren't the brakes linked so that the bike/trike tries to determine what is best needed to stop.
What is a linked braking system on a motorcycle? A system that engages both brakes when either lever is applied. A technique in which the rider uses both brakes at once.
You have asked a very loaded question and one that has lore than one correct answer depending on the Bike/ Trike manufacturer
Linked brakes are just what the name implies. The brakes on both axles are linked hydraulically be it diagonally or in most cases the front calipers are linked to the rear brakes when multiple piston calipers on the front axle have ( typically) center pistons applying pressure to front brakes via rear braking until you grab a handful of the front brake lever also to fully activate the front brakes
The braking has nothing to do with the bike/ trike knowing what is best EXCEPT when you throw anti lock and traction control into the mix
Now you have a computer and specific hydraulic valving involved along with wheel speed sensors very similar to how ABS works on your family car
I hope this answers your questions
Keep in mind all manufacturers use their own ( made for them) set ups
All of this helps - thanks.
My bike has ABS and, also traction control. When I talked to my trike builder, he said that all of those functions will continue to exist when the unit is triked.
The Harley Tri-Glide, for example has ABS and traction control - so, I have to imagine that when I trike my Harley, since it is already there, those functions will be working just fine. I do know that when I was ordering the trike kit, it sated that if my bike currently have ABS, I have to get the trike ABS package ($300 cost)
brakes
I don't have linked brake option on my Trike. Rider brain link only! lol
Brian Duprey
