Well after a month of research on line and riding two Gold Wing trikes, one a Motor Trike solid axle and the other a CSC IRS, I decided on the Motor Trike IRS.
When I rode the two trikes and turning into a curve at relatively slow speeds I felt that the front wheel was sliding toward the outside of the curve.
Have you experienced this and how did you overcome it? Mentally I get the centrifugal forces and the steering but not the sense of the front wheel sliding. Also from this message board I understand it takes several hundred, if not a couple of thousand miles to be completely used to the trike. I should have my trike by the end of June. I should also mention I have been riding two wheels since 1973. Whoa! Did I say that?
I would appreciate your words of wisdom.
