Does anyone know where I can find spinner hub caps for my 2009 tri glide?
As far as I can tell on this forum, I was the first with this mod. As posted before, I learned one tip that I mentioned in my post before. That important tip was: My first set that I made worked out great until I was riding in the city of Cleveland and lost one hub cap with a spinner. After hitting the usual potholes with nothing real violent, one came up missing.
So I made up another set, but I made a simple modification to the installation process. Just before installing the hub cap to the wheel center opening, use some silicone to the prongs that slide into the center of the wheel. Don't worry about using to much. Slide the cap into the wheel in the evening and the next day your good to go! When you want to remove them for any reason, no problem, as they will come right off with a firm tug.
As to the issue of getting the center drilled on center, I had no problem using a combination square with the "V" to find centers of circles. I then drilled a small pilot hole, and drilled it larger to the correct bolt size. Then when I bolted the spinner to the cap it was really close! If your a perfectionist like me: I made sure it was spinning perfectly by using my old turntable and checking it. If is off slightly, just loosen the spinner and slightly move it and then tighten it. I also put a dab of silicone on the center bolt and nut too, just for insurance.
Hope this helps out.
ThumbUp
I received the spinners yesterday. So I’m starting with two spinners and two dome hubcaps that I had already had on the wheels. The first order of business was to pry off the aluminum trim rings. This will give a flat surface for the spinner to sit in. There is a gooey, foam adhesive left behind that can be scraped off and cleaned up with “Goo Gone”.
I used my bowl foot chuck and mounted the hubcap in it to drill the pilot and final hole for the 5/16-18 bolt. Final assembly and install tonight. Pretty simple to do with parts matching up well.
TNT: I didn't find it on e-bay. Try Wheel Spinners and Accessories: Spinner Center, Specializing in Classic Tri-Bar Wheel Spinners
