Mike try 20lbs in the rears ,41 upfront,Lehman shock put on the middle setting and Honda rear suspension starting at 7. And try tweaking the ride witth the Honda shock settings.
even better at 15 lb, we ride two up and the tires have been at 15 pounds for the last two years---no noticable tire wear and sticks to the road like glue Champion solid axle
Thanks Mick, I called Lehman and talked to Lori who was very helpful. I then jacked up the bike a little and found the spring, but wasn't able to either see what it was set on so I just left it. Since I only have a Sears jack, and no jack stands, I didn't want to get under the trike. I'll just leave it as it (my guess is that it is probably already set in a middle setting), and have my tech check it when he does my next service. I am thrilled at the ride as it is, and can't imagine that it changing the Lehman shock will make a big difference. I love the handling and reliability of the solid axle, and now with a decent ride I am very happy.
Thanks for all the suggestions... ThumbUp
From what I have been told it is the passenger who greatly appreciates the ISP much more than the rider. As some of these folks say, "happy wife, happy life".
Good points, especially the work truck reliability, and I agree 100%. After my Spyder stranded me I want reliability much more than a soft ride. The GM at my dealer mentioned that the solid axle has far fewer moving parts, less chance for problems, and that's what I want. I love my solid axle. Now it's off to the dentist to have some fillings replaced.![]()
Wow, what a difference. I lowered the Honda preload on the spring, and lowered my rear tire pressure from 22 to 20, and the ride was noticeably smoother. I didn't see a Lehman spring, nor did I increase the front tire pressure (currently 36), but just these two changes made a huge difference.
Thanks...
Just checked to Owners Manual and it recommends 36, but that's not on a Trike. Should I increase it to 41?
"Most" Members, including myself, seem to have much better Tire wear, and especially less "cupping" using 41-42 lbs in the Front Tire...I finally settled on 42.....ThumbUp
Thanks Skuuter,
Rather than wait for an answer I changed mine last night to 41 and I'll see how that works. If the issue is tire wear and cupping I guess I won't notice much difference, but I'll leave it here for now. Thanks for your help.
