SMALL LEAF BLOWER (2 cycle)
Baldy_54
1750+ Posts
Dec 18, 2010
1,925
7,914
MD
Bill
Would it hurt to put a small amount of "SeaFoam" in the tank to clean up the carb. etc??
Noperz. Those things need ALL the Prev. Maintenance help they can get. Don't know what's more aggravating...
Cords 100ft+ long or finicky little engines. Pick ur poison I guess.
Having been in the small engine repair business for quite a while, I recommend the Sea Foam. As to two cycle oils, Opti 2 is the best I found. You can also run the Opti 2 mix in your other lawn equipment and have only one fuel can. It's smokeless and actually helps the four cycle equipment work better. These days, too, gasoline is being offered that contains two cycle oil, but no alcohol. Expensive, but you really only need to run a tank or two at the end of the season before you put the unit away and, hopefully, preserve your carb diaphragms and prevent gum up.
I learned that a long time ago and went with rechargable Ryobi 40V edger, weed trimmer and blower. They alll share the same battery which last for 2 cuttings for me. The only thing gas for me is the lawn mower and they seem to have a large enough engine that they don't seem to share the same problems with the very small engines that are always hard to start after they are over a year old or so.
I put MMO (Marvel Mystery Oil) in all my vehicles and lawn equip plus my trike and have for years.
o~\o
Not at all, go for it.
Thanks Bazooka, I was looking for my post yesterday and could not find it. Thought it had been deleted because it was not motorcycle related. I took "Discuss Whatever You Like" to mean just that, since it was listed under the "general discussion" location.
Great advice! I run that year round in a Stihl S90 (almost bought a Core brand rechargeable Trimmer when bought that) and that thing never gives me any "crap" anytime. Using it last two fills at end of season in all small implements would make good sense. Thanks.
Thanks for the review on that unit. Had a rechargeable once and didn't like it as was weak and didn't last. Sounds like you found a quality tool that does. When the Stihl finally lays down will look the Ryobi up. Just wonder how would fare for the tougher jobs here on the Farm like the pasture fence rows, around outbuildings, and clearing brush for Deer Blinds?
I like Lucas products. My Granddad was a Lucas Man (and a small engine Surgeon/miracle worker) so you know how that Family Tradition bias runs strong from Generation to Generation. Probably same with all preferences for all Brands.
I was at the end of my rope with gas weed eaters. the green ones last me about 1 year and wouldn't start the next spring . costs about as much to get one fixed as it does to buy a new one.
ran across a factory re-furbished echo weed eater and bought it . I use stabil in my gas and have used this one for the past 5 years. starts every time.
buy good stuff and you will always be happy or really p^ssed that you wasted that much money.
Even fairly cheap equipment can be made to last properly cared for. But, if you don' know how, it is a fact that it is just as economical to replace rather than repair. Most outdoor power equipment shops work by the hour, with some charging flat rates. That and parts can mount up pretty quickly. The newer Ryobi trimmers, for example, were about $90.00 for a new power head and upper shaft. I couldn't do any kind of repair or service on those, as my cut-off point was 50% of replacement cost. All I would do on equipment like that was tune the carburetor, for which I did not charge.
A clarification on my winter storage advice. Use one of the non-alcohol two cycle fuel mixes (there are several - I liked 50 Fuel and 40 Fuel - reasonably priced work well) and run the unit until it is empty. I recommend at least one tank full at the end of the season to condition the carburetor diaphragms.
If you want to step up from big box store product I seriously recommend Stihl, except for their least costly products. One reason is that a vast majority of their product line is manufactured right here in the USA in Virginia Beach, Virginia. Second, Stihl owns Zama that makes most of the carburetors for just about every two cycle unit manufactured anywhere so Stihl can offer better pricing. Third, their dealer network is unmatched by just about any other manufacturer. Echo comes close, but I became very unimpressed with their product once they sold out to the big box's..
As a Home Depot tool rental manager and "in charge" of our stores repair department, Ryobi warrants their equipment for up to 5 years...but not on fuel related issues. We STRONGLY recommend the use of ethanol free unleaded premium and synthetic based 2 cycle oil in all small engines. Fuel related carburetor issues are 93% of our repairs. We see, on average 25-40 weed eaters and blowers a week. Lawn mowers...this time of year..10-15.
Good advice, but where does one get ethanol free unleaded gas these days?
Figures, the only places that have alcohol free gas are over on the Eastern Shore of MD and that is at a minimum 125 miles away. Guess the only smart people are the farmers over there.
Update: Apparently, that list is not up to date, found a lot of stations when I searched ethanol free gas stations in MD. Need to go
check one out.
I use a stihl leaf blower (for leafs and to blow dry the trike.) , an echo weed eater, craftsman 2 cycle rototiller, a cub rider, and a husky chain saw.
I want one of those pull behind lawn vac's. lots of leafs here and my back hates using a rake.
Use Stihl Trimmers, Husqvarna back-pack Blower, and Jonsered Chainsaw.
The Stihl is very reliable, the Husq is 25 yrs old and starting to get "grumpy" on me and the Jonsered is absolutely BULLET-PROOF. 22 yrs. old, fires up every time on second or third pull and still slicin and dicin like it was a new-born.
Thankfully, here in the KC area, I have 4 stations within 5 miles that carry TESTED ethanol free premium!
As much as I hate ethanol, I remember before it existed having small gas engines needing carb overhauls because of gumming up. The best advice I've gotten is you got to start them about once a month and let them run for a few minutes. Gas gets old regardless and will leave gummy deposits.
I keep about 40 gal of fuel (gasoline ) in reserve during the winter months. had an ice storm shut our area down for about 3 weeks a few years ago. nice to have a generator when that happens.
I put stabil in it then use what is left over all summer in my boat and yard equipment . have had 0 problems with gumming. I am not a paid spokes person for stabil, but the stuff works.
I see this thread has gone from Seafoam to Stabil and back and forth. What I would like to know is, do these products have the same helpful qualities? Like if,
one was not available could or would you use the other? Thanks.
Stabil will work to stabilize your fuel ahead of time. You have to run it thru the carb so it can get into the small orifices and keep the diaphragm from getting gummed up.Seafoam can be used to clean out the orifices AFTER you have let the engine sit all winter with no stabil in the fuel system. Seafoam is also good in the crankcase where you believe needs cleaning. A certain amount mixed with engine oil then run for some time to agitate then drain. You will be amazed how much comes out. So to answer your question, the two products are used two different ways.
Seafoam is a good thing, also with all those type of small 2 cycle motors another thing you can do to keep them running well is to remove the muffler and soak it in a pail of seafoam or other carbon dissolving solution, then blow it out. What happens over time is the muffler plugs up with oil and carbon residue and it won't run. I have pulled countless numbers of weed wackers and chainsaws out of the garbage that wouldn't run for just this reason, clean the muffler out and they run like a champ. ThumbUp
I tried to give Ragtop a "Thanks" for a post that I thought was something that many would not do or think to do. But I guess I did it wrong. So Thanks Ragtop.
Glad to help, you'd be surprised what people trash just because they don't know. I'm good with that, puts gas money in my pocket. ThumbUp
My last pick was a nice looking honda self propelled mower, Got it home, it had spark, was getting gas but wouldn't start, turns out the air filter was packed tight with dirt and spider debris, fired up and ran like new with just a new air filter. The next week I went back looking for him to throw out the bagger, when it didn't show up for 2 weeks I knocked on the door and asked about it, the guy gave me a mean look and slammed the door in my face! pepper
Geezer Glide
