Shock adjustment
Rogue1
400+ Posts
Oct 8, 2018
570
592
Ramseur, NC
Dale
Question to anyone running the progressive 444 4073b shocks. The instructions don't give any indication on what settings might be good for a certain weight. I'm just curious as to what settings you are using. I'll be running a total weight of about 380 lb total weight without gear and I currently have it set on four. It seems fine with only me but I haven't been two up yet. Just curious
You will have to measure the difference in the sag with only you and then 2up. If there is a sliding bump stop it will tell you how close you get to bottoming out . I would test it solo on a ride. Then Progressive should be able to tell you what a click or turn equals in weight.
dyno56ca
