Shims
Oct 10, 2013
176
11
Harrison,Ohio
I have some tire rub on inner fender mainly right side, when on not so smooth roads. trike body is slightly lower on right side also. Does anyone know where I can get additional shims like the ones,that are currently on the trike. Im referring to the ones on under body of trunk where 4 bolts go thru. This is a 05 Monnarch II solid axle. Thanks for any help.
Would different thickness washers do the trick?
Bozo I was thinkin the same thing, but was curious about getting additional stock ones because of thickness. my initial thought was adding one more stock shim to each bolt, then adding washers to right side to level out if need be. Thanks
found the problem, where the 4 bolts go thru lower truck to chassis, I found one bolt loose with no shims at all. So added shims (washers) to that problem plus to the other bolts,raising in about another quarter inch. So far no issues. Thanks
Gyl
