shakes
this trike is hubby's first shot at building trike he has learned alot from this one and already planning a second one
geannie mine is built with fiberglass body also.Now what I have welded to bottom of down tube is weight filled pipes [3, 14 inch pipes] out of the way. Another problem I had when I bought mine was the wheel spacers were loose [you could spin with fingers,not good] so after tightening took away high speed shake.Hope this helps in some way but, I believe with just first gear shake its still in flywheel or clutch........NOT a mechanic, just past problems with big trucks.
Like I stated I was not a VW mechanic,but I read the article Doug D posted that would be where I would try .I do hope you let us know when you do find it and sure you will.
Trike#1
