Sena SMH 10 radio
Jan 5, 2014
68
3
Jackson, MS, USA
My friend and I are wanting to get radios so we can communicate on rides. The Sena SMH 10 looks good but I'd like to know if any of you have first hand experience with one.
My wife and I use them and they work very good.....as advertised. It takes a little time getting everything paired. We each have our phones & Mp3 players paired to our individual helmets & of course the two headsets paired together. The only downer is that when you do a firmware update, you have to re-pair all the devices again.
They have very good range and the music is crystal clear. We use the one where you can plug in earbuds. Since we have full face helmets, we also use the microphone that sticks to the inside of the helmet. The boom mic works fine, but you have to make sure it's directly in front of your mouth or it's hard to hear the voice over the wind noise. When the mic is positioned correctly (whichever type you use) it picks up very well & is very clear even though there is some wind noise.
The controls are easy to use even with gloves on & the voice activation works as described. The latest update allows you to share music between headsets. In the past, each headset had to have its own music source, so it's one less device to deal with.
I haven't used any of the other systems so I can't compare. When I did my research a couple of years ago, it seemed that Sena had far more features and possibilities than the rest. I am very satisfied with it!
sena smh-10
i am in the process of using the sena smh-5 but i am at the point on the screen it is asking for a 4 digit pin? where the heck is that at? thank you all for the help. jim
Sena 20S
I use the Sena 20S and have found it to be excellent. It has a range of 1.2 miles in open terrain and you can have a group intercom setup with up to 8 or 9 other Sena units. This link is for a site that does evaluations on all kinds of motorcycle products and I find they are spot on:
http://www.webbikeworld.com/
Gray_Ninja
