S/A meaning???
Sounds like solid axle is what they mean. Anyway it's not IRS since the whole assembly moves in unison. I asked because I always called it solid axle, but my mechanic the other day referred to it as straight axle which also makes sense to me since it goes straight from right to left wheel and IRS is from what I've seen angled to each wheel where it can move independently.
I would call it a straight axle. If it was a solid axle there wouldn't be a differential in the middle, so you would have trouble turning. JMO
Larry
Trikes today have two types of suspension (Axles) Solid which is a single bar going across powering the drive train.
Independent Rear Suspension (IRS) Allows each wheel to be powered independently. IRS is more costly, more comfortable for the passenger and is much more complex than the solid axle.
It is straight axle. It is refering to the linearity of the wheel drive shaft system. Of course, we know there must be a differential to make the mechanical system work (allows each wheel to turn at different speeds). Solid axle refers to one solid shaft with no differential between wheels.
This was the best explaination.
dcbjr
