Rubbing noise
jjvw
700+ Posts
Dec 5, 2013
760
825
Jenison, MI
John
I have a champion kit on my roadstar. We have 50k on the kit. On a ride yesterday, we noticed a rubbing sound as we did a left side u turn. I haven't tried a right side u turn yet. I check tire clearance and lug nuts. It sounds like rear drive train noise to me. Belt tension is ok. I had the body off, last summer for a check up and everything was tight and in spec. Any ideas besides not doing u turns?
Jan & John
Thanks. I will do that, when I get thru rebuilding the TBI in our motorhome. Gramma wants to camp on the beach next week.
John, check your shocks. Might be a tire rubbing when under a load. Where is your shock preload set at? You can rotate it a notch or three on both sides to increase preload and that may cure the issue, or if they are the original shocks, it's probably time to replace them.
Jan & John
I have the same issue what was the fix for you
thanks
Jan & John
Is that Independent Suspension?
AishaK698
