reverse shifter
Depending on the type extension you got, that's pretty much the case. You'll need to either leave or add a "jam nut" on the origional shifter so your extension stays where you want it. For some reason, locktite doesn't seem to work well in this aplication. You can find shifter extensions at almost any truck stop -- straight ones, bent ones, etc.. Just pick up the proper size thread that matches your shifter in the shape you want. Take your knob to an auto parts place & see which bolt screws in easily & match that size, unless you're like me & can "eyeball it". The shifter extensions are USUALLY the same thread on both ends except one end is "male" & the other "female". It states on the package which thread it is.
NM
I don't know if champion has changed their shifter, but mine is about 4 years old and the black handle was glued on. No threads on the shaft.
Thanks trikers, for that info, I'm looking at installing a draft beer handle I saw at a local hang out. It's a Fireman 4 draft beer handle, its fire engine red and has a number 4 on it. I'm a retired fire Captain from Station 4. If every thing works out i'll send some pics.
Chef: I also installed one of Ultraboys extension & it worked & looks great. One of the problems you may have with the Beer Tap handle could be clearance as some of them are quite high....
Roger71!!
