Reverse motor repair
Jul 24, 2011
14
Shirley, Indiana
I have a 2011 Tri-Glide and the reverse motor is very weak. You can hit the switch and it goes back a few inches then stops. I do this 2-3 times and it eventually just stops. The first thing I'm going to try is check the battery and make sure it is good, but if its ok; I wondered if the reverse motor could be rebuilt. Hate to drop $1300+ on a little electric motor. If I have to do that, I'll just put a baker or whatever in the tranny.
Besides checking your battery, check the connections to the reverse drive to make sure they're clean. If it is the motor you may be able to get a shop that works on starters to repair it, its basically a high torque starter.
you know if your going to drop 1300 bucks on a motor I would just go to a mechanical reverse..Far better than the electric version IMO
I have heard that when using rev. that if you increase the RPM that it helps, don't know ?.<br />
how old is your batt. that's the 1st place I would go. good luck.
Just had mine replaced under extended warranty.
+1 on M3, I would check all connections, and that the battery is good. If it is the motor, then you can probably find a local shop to rebuild it.
Before spending too much on it, I would check out the mechanical reverse options.
That said, I rode for quite a while with no reverse at all. Just had to be careful where I parked.
Same problem I had with my 2011. They replaced the motor under warranty. Make sure solenoid is good. It is probably the brushes in the motor. a good starter rebuilder should be able to repair it if it is not under warranty.
cant the manufacturer of the starter make the repairs or is that another have to go thru the dealer product??
I know when my fails its going in the garbage..Cant stand the electrical drain when you hit that button..
When my reverse motor was replaced on'10 TG, new motor had higher torque and speed. Same P/N. Warranty covered it.
Original manufacture of the motor is more likely in China. Would cost as much as the purchase of a new motor in freight. No doubt the motor is re-buildable. If someone does motorcycle starters they might have the parts on hand.
You might call customer service & bitch for a while. Or at least explain the problems with their choice of an electric motor reverse & see if they might go ahead & stand good for it.
If you have an '11 year, does it have extended warranty? If it does just let Harley have at it ! Don't worry about it !
One more reason I carry a long warranty. That motor replacement alone is over half the cost of the warranty.
I belive the manufacturer is in california? Yea if you have a wanrranty go for it..out of warranty a mechanical one is in my sights..
:Coffee:
Drop me a note before you pitch it in the trash. A friend of mine has an electrical motor repair shop and would like to give one a try. He rebuilt a 36 volt motor for my satellite dish and it is beefier than new.
when mine takes a dump..I will drop you a note..
I have a 2011 and before the original two year warranty ran out the reverse had to be replaced twice. When it went out the third time (4th counting the factory original) it was over the two year warranty. I asked about a "lemon law" as I had some other issues with my 2011. When the fourth motor came in, it had a different part # than what the first three had. Because it was a new part # like there had been a factory "update or recall" and it was past the two year mark No Lemon! The mechanic said they had put water seals in it and a small drain hole in the bottom. Which says to me there was a problem a water issue and the electrics. My.
Dealer did not charge me the $50 deductible for my extended warranty which was nice.
At the time I was having the 4th reverse motor put in I had something over 20,000 miles on it. Close to 25,000 now and no problem and I do think this new part # has more torque.
As a side note I try and be aware of and how I park as to not to have to use the reverse at all possible. When my extended warranty runs out she will have a mechanical reverse!
When it went out the third time (4th counting the factory original) it was over the two year warranty. I asked about a "lemon law" as I had some other issues with my 2011. When the fourth motor came in, it had a different part # than what the first three had. Because it was a new part # like there had been a factory "update or recall" and it was past the two year mark No Lemon! The mechanic said they had put water seals in it and a small drain hole in the bottom. Which says to me there was a problem a water issue and the electrics. My. Dealer did not charge me the $50 deductible for my extended warranty which was nice. At the time I was having the 4th reverse motor put in I had something over 20,000 miles on it.
I hope this one holds up for you.
I'm at 50k miles and only on my second one. Yesterday I had a new noise/rattle. First thing I checked was to make sure the reverse motor wasn't loose. lol
Ended up being a broken heat shield clamp. :)
I have a 2010 Harley-Davidson Tri Glide ULTRA CLASSIC Trike and it is not under warranty. The reverse is quite working and the price to replace it is 1400 now. How hard is it to remove and is there a site to go to that shows how too? Want to try and get it rebuilt before I pay that much. also does anyone know a mechanic in central Florida the place in Sanford I go to has closed.
Had mine rebuilt on my 11 T/G Very easy to pull the motor out, I brought the motor to a rebuilder and he did it while I waited' Took about a half hour and 95 dollars..
The motor is an Hitachi..
Middlesex Armature Service.
Middlesex N.J.
732-634-3779.
Middlesex N.J.
732-634-3779.
I believe Rhino also advised that he spoke with the above business and they were willing to do mail in repairs. Give them a call and send the motor to them. Good job Rhino
Middlesex N.J.
732-634-3779.
Here is the web address for the shop that repaired Rhino's reverse motor -
http://alternatorsandstartersnj.com/
I wonder if it would be worth creating a sticky or something like it to provide the info about this shop since the topic of TG reverse motor repair seems to come up often?
If this shop is willing to receive & ship the TG reverse motor than they would be a good resource for TG owner everywhere. I know that not everyone looks at the Sticky's first, but if there was something there it would make it easier to point someone in the right direction. Just a thought.
Hey,
I had the same problem,took the motor out and apart,I found out that one of the lugs that hold the end cover to the motor was cracked off.
had it welded an it broke again.I WILL NOT replace it,I am going to go with the gear drive set up for that kind money,Harley does not sell any parts for the motor,I think it is CRAZY that make you buy the whole motor!:pepper:
Hey,
Have you talked to any shops that work on electric motors? It might be repairable or if not,they might be able to match it and sell you a new one for a vastly reduced price.
If the motor is ok & just needs brushes replaced, which is the biggest problem the motor has as it seems. You can get a new set of brushes w/plate, (assy) for $49.95 0n EBay.
On my 11 T/G The first time the motor went south, i pulled it out, clean and reset the brushes, it worked for a while, The second time i brought the motor to an old school shop and he rebuilt it while i waited for 95 dollars cheap at twice the price..
That lasted for about a year.. Road around for a while without a reverse and having to be careful where i parked. Then i finely got tired of crawling under my trike to pull the motor so i had in a mechanical reverse put in.. Now i can park my 30 thousand dollar machine any where i darn well please..ThumbUp
Actually it was 29... But whats a thousand 'Here or there among friendsThumbUp:laugh:
Reverse motor repair shops or mechinal reverse?
I realize this is an old thread but I have an old '11 Tri-Glide with a dead reverse motor.
I tried "Rino 2" web site http://alternatorsandstartersnj.com/
but internet explorer sends this message - could not find. I have the following address and will try it.
Middlesex N.J.
732-634-3779.
Has anyone else had any recent experiences with dead reverse motors?
Is there an update on repair shops? Mechanical reverse who sells / installs them?
For now I will watch where I park. Sorry for all the question and thanks in advance. DJ
Middlesex N.J.
732-634-3779.
Middlesex is where i had mine rebuilt...It worked for a little over a year, After that i bit the bullet and had my dealer put in a Motor-Trike Mechanical reverse... I Should have did that the first time...
Look at my post number 18..........
Reverse Motor Repair
Check the website for Performance Alternator and Starter in Canton OH.
http://www.performancestarter.com/
Note their claim of "Lifetime Warranty" at the top of the page. And, no, I have no affiliation with them!!! Their video is very interesting.
My reverse motor died it's first death at 24K and out it came! Motor Trike Mechanical Reverse in its place. Very easy to remove the factory electrical motor. Pop the 50-amp breaker; disconnect the two wires and tape them off and secure to the frame; remove two bolts from the starter and it's out!
It's laying on the bench in the garage and may get rebuilt (or scrapped) someday, but I'm very happy to have mechanical reverse now.
Did you verify with them they would rebuilt the HD reverse ?
RCK TMS trike
