Reverse Motor on ULTRA TRIGLIDE
Aug 23, 2010
11
Jamestown, ND USA
I have a 2009 Ultra Triglide the reverse motor is going bad, can I take that to a place where they rebuild starters for cars and trucks? They are about $1500. plus labor to replace.
  • Like
Reactions: MDO
Yes you can, Just as long as they understand its ''not'' a starter motor, but a high torque low RPM Spining reverse motor....Made by Hitachi....
Reverse Motor on Ultra Triglide
On my 2009 Ultra Triglide the reverse motor stopped working. I removed the reverse motor and took it to a Auto Electric Technician. He said one of the brushes was badly burnt. It cost me under a $120. to get it done. He did say that these reverse motors are geared down and the small gear doesn't turn that fast so motor is winding pretty fast. So if you're backing up long driveway do it for 30 seconds than let it cool for 30 seconds. They get pretty hot. I bought my trike back in 2013 so I don't know how much it got used. If I use it within reason it should last a long time. I'm pretty confident in this place and it saved me a lot of money.
Great updated Info since the early years of the TRI on reverse motors:clapping:
My preference is still the mechanical type:D
Yep, When the reverse 86's on my 17 Tri after the warrteny is up, Just like i did with my 11 Tri. I'll go Mechanical ... It was nice to back out at any speed i wanted to just like a normal vehicle......:clapping:
I have a reverse motor I'd like to sell. Good condition.
I got the reverse gear kit from Papa Zook, it's so nice to have a real reverse that doesn't wake the dead and jerk you back...
While I had the right rear wheel off, installing the Pro Action shocks from Kevin at DK, I pulled the motor out of there since I won't be needing it any more. I also got rid of the switch and the harness on the left handlebar. The Yaffe Monkey Bars look so much better clean with no wiring showing.
I see that Terry Components came out with a rebuild kit for these reverse motors, $300. I'll give somebody the whole motor for $300. Make me an offer. Can we still do PM's on here?
Jack - What's the cost on a mechanical reverse.....most likely installed. Unless you can talk me thru it!!
jc
I had it installed on my 2011 Tri...The motortrike reverse with the lock out harness,
If i remember correctly 15 hundred dollars...And Worth every penny...
Tozbro
