Reverse Gear
Jan 20, 2020
7
13
ENNIS
Was backing out of the garage today. Reverse was very weak and then quit. Acted like the battery died. However, this bike remains on a trickle charger at all times when not being ridden. Also, the shock pump (2019) was malfunctioning. Obvious electrical problem. Has anyone had a similar problem? I am a few hundred miles from the nearest dealer and in this environment, we are on lock down. This is a 2019 Roadmaster with a Tomahawk rear end.
Just a thought , check the battery ground to the frame . If your having problems with more than one item :Shrug:
Eddienorman
