Relay removal with trike kit
Jun 27, 2011
178
Tennessee
Teal
1500 champion trike
i need to access the relay box and cant get the cover past the body,, any suggestions. i lost all Brake lights
thanks
I am not real familiar with the GL1500 trike, but I would check the fuse block for a blown fuse first, then look at the trailer harness second if you have one.
If the fuse is good check something else on the same circuit as the tail lights and see if it is working. I don't think it is a relay. Maybe a lose plug for the tail lights.
You have a 2011 trike kit so you should have a warranty. Take the trike back to the installer and have them trouble shoot the problem.
had same problem had to cut the cover. Hope someone tells you a better way
thanks,,, got lucky- it was the sw needing lube, not relays
to get the relay panel cover off -- have to remove the fiberglass,, doesnt look that diff either.
no to taking it back to the dealer,, if it broke down in front of the place i would tow it home.
Joe Henry
