Rear tire wear on my '06 GW with a Hannigan kit
Sep 13, 2015
4
Belton
I'm noticing that both my rear tires wear much faster on outside than the inside. Anyone have any ideas? Is there a way to adjust the tilt? You can see the tires are tilted when you look from the rear. Any thoughts would be appreciated.:confused:
You need a camber alignment. Should be done with rider on trike or rider weight on seat. A good alignment shop should be able to do it.
Camber/Caster Alignment
:xzqxz:I have a CSC Cobra XL on my 2003 GL1800. Can the Camber/Caster be adjusted by simply loosening the locknut on the axle brace and turning the Clevis in 1 turn and tighten lock nut? My tires are wearing on the inside both rear tires.
dhinzman1
