Rear shock adjustment
Jan 7, 2023
2
EL PASO
Hello, I'm a new member from El Paso. I have a 17 freewheeler, and a question. First of many probably. I've been looking through the forum and it's a great resource.
My question is, do the freewheelers have air shocks like the two wheel touring bikes, and if so, where is the valve to add air? Also what would be a good general air pressure for single riding? Thanks so much.
It's under the right side cover. I run 15PSI when solo with a dog dog carrier. When packing a passenger I'll add more - it depends on your weight. You'll need a dedicated pump- like the one HD sells. I wouldn't use a compressor.
thanks a lot.
thanks a lot. Should have looked there first. I appreciate the help.
nmbr1soonerfan
