rear bumper
Feb 11, 2012
70
Parrish, FL
I'd like some ideas on putting a rear protector / bumper on my Champion IRS trike. I've searched for information on rear bumpers but found nothing specific on what to use or where to buy. I found a tread about nerf bars but got the same results. If any of you have made your own or modified something that works, would you please share how and what you did.
Ron
Ron,
When I designed my bumper I had the 2 brackets welded just o/s each rear body mounts.They are only 3/4" wide X 1/8" thick - made to brace the ends of the bumper.My bumper is about 1 1/2" higher than the hitch.
Each kit (Hannigan or whatever) would need it's own style of mounting and bracing.My brackets go under the trike about 2" and then I added an angled piece to attach to the frame-makes it easier to remove.
You could also mount your bumper to the top side of the hitch and still pull with it.Also,if you build one be sure to have a way to run wire thru it if you ever want to add lights.
Have fun,
Tip
Bumpers on Honda trikes are for show only and do not provide adequate protection if any in an accident. Most are Nerf bars or light bars and are very expensive. Some bumpers interfear with the use of the trailer hitch.
Scott,
Speak for your self!I have a honda trike and my bumper does protect the trike from minor bumps.It was not built to protect if from a major accident - nothing else will either!
Tip
Scott,
Tip
I did speak for myself. Don't take it so personally and I wasn't attacking you. Take the information for what ever you read into it. Most are not going to build there own bumper and mounting brackets. They will buy what ever the trike dealer has. Greg
Cahampion has this: Products
Looks like it goes into the hitch, and is more of a light bar than bumper. Haven't seen one in person or any other photos, so dont know how far it extends past the bodywork, if at all. Problem with putting on a bumper on a Champion is that the lower trunk door is so low there isn't much room for a bumper, especially if towing a trailer.
Here is a set of bumpers someone makes - the attach to the fibergalss on the raised panels on either side of the trunk. Champion Trike Bumpers
Delverc
