Rear brake light switch
Has anyone replaced one yet it looks like I have to pull off the header pipe
It will give you a better shot at it if you pull the pipe down and out a bit. I am going to replace mine soon, 2017 Freewheeler 107. If I cannot get mine off with the crows foot wrenches I have I will move my front exhaust pipe also. Good Luck;)
Jack, on my 2015 Freewheeler the switch was replaced in a matter of minutes without moving any pipes. Thanks to you, I was able to look up the code and part number.:)
How do you loosen the pipe enough to pull it down and out?
Loosen both exhaust pipe flange nuts, remove the bolt from the head pipes exhaust hangar ( look below the front pipes ) there is also a hangar at the cross over you can remove the bolts on, the exhaust can be lowered a bit now and blocked away from the area you need to work on. There should be enuff give in the rear muffler hangars to get this done.
dyno56ca
