PV-1 map for 05 HD Lehman, 103 CID, 203 cam
Jun 7, 2013
83
4
Middletown, NJ
Does anyone have a PV-1 map for an 05 Ultra w/ Lehman Renegade rear, 103 CID, #203 cam, Hypercharge air filter and stock pipes? If not, any idea how I can modify an existing map? I am a newbie to this tuner.
Has anyone used the Autotune feature of this tuner? Results?
Thanks.
Wish I could help you, its going to be a tough nut to crack since you don't have O2 sensors to self tune by, only other way of tuning is with a dyno equipped with a gas analyzer.
CAll or e-mail Dynojet and discuss your configuration with them and they can possibly build you a map. I have the PV-1 on my 2013 V-Rod and one on my 2013 H-D Triglide with also the Auto Tune Module and love them both. I installed a 120r Cate Motor in my Trike, and after discussing my specific configuration with one of the Techs, they built me a map to start with.
Good like, Dynojet's customer service has been awesome and timely in their responses.
Roger
Roger
Yeah. That's what I did. They sent a map that so far is working out just fine. I want to up the idle a little, but other than that, all is OK. Peppy. Good response to the throttle.
I guess my ride didn't have 02 sensors. When did they start installing them?
Will I need 02 sensors to auto tune?
Thanks.
Thanks.
07 is when HD went to the O2 sensors in the touring line. If you bought their Auto tune kit it comes with wide band O2 sensors which if you don't have the bungs in your head pipes already, they'll have to be drilled and the bungs welded on.
You definitely need either narrow band or wide band 02 sensors to auto tune with the Power Vision Tuner!! With the factory 02 sensors you can only auto tune in the "Basic" mode!
Roger
Marks2024
