I've looked into installing Progressive springs in my 2004 Wing with a CSC conversion. I'm sure there are others that have done this. I would appreciate any feedback pro and con.
Moring Fred. Mine is a MotorTrike but I can't see that would make any difference.
I put progressive springs in to cure the dreaded sag after conversion but I think that might have been a mistake. The new springs made the front suspension so tight it beats me to death on rough roads. I've got about 45,000 on my trike now and next time I rebuild the forks the progressive springs are coming out and a fresh set of OEM will go in. OEM springs are not expensive so if I have to replace them with every fork rebuild (every 25K) I'll do that to keep the ride level and soft.
Hope that helps a little at least. :xszpv: :xszpv:
I appreciate your comments. When you went with OEM springs did they raise the bike back up to normal height, or did it still "sag" as a result of the 6 degree rake?
There are longer top caps that can be used to get the front end back up to a level ride.
The TRAXXION caps even allow for adjustment.
