I just ordered the Progressive 444 shocks 13.5" HD. This is the TriGlide specific model.I already have the DK lift brackets installed .Will I need to replace them with the stock brackets?
Thanks in advance, Wayne
Thanks MJ .That is what I did. When T-Glide goodies tested their brackets at 1-1/2 " lift he said it was too sensitive at hiway speeds. I would think 1-3/4" would be worse (1-1/4" lift + 1/2 " longer shock). Maybe when good weather gets here I will swap the brackets and road test it.Yes you will need the stock one being that the shocks are longer i tried with the comfort lift the exhaust is very tight to the frame i reinstalled the stock brackets and the shocks are fine no problem with the exhaust
