Pro Action rear shock install question.
When you all installed the Pro Action shocks, did you install them with the adjustment screw facing away from the tire or facing the tire?
Install your new Pro-Action Shocks reusing the same shock bolts and red thread locker.Tighten to the torque specs specified in your service manual. Install them so the clickerfor the rebound damping is easily accessible for adjustment. (typically on the bottomfacing away from the tire on 2 wheelers, and for Trikes, on the bottom facing the tires.)
Above is excerpt from full instructions which can be seen at this link-
https://www.dkcustomproducts.com/me...-Action_Rear_Shocks_Instructions_10-15-18.pdf
wzejda
