I finally got the trike out during a break in the rain after replacing the front wheel, lubing the heim joints, replacing the pinion seal, replacing the air bags digital circuit board, and removing, cleaning, greasing, and replacing the drive shaft. I now have a slight vibration from 0-25 to 30 MPH that wasn’t there before.
The two pieces of the drive shaft separated when I removed it so I’m guessing at the position of the two halves. A Manual of my MT Spyder Coversion written by another MT owner said if the vibration happens, to remove the drive shaft and slip it one spline on the shaft. Would moving the drive shaft make that much difference? Any suggestions from anyone that has removed and replaced the drive shaft are appreciated.
