Something Pet Carrier owners may want to try. I tack welded the mounting nuts to the flat bars. Drilled a taper in the flat bar opposite the nuts with a 1" drill. Replaced bolts with round head, hex drive ones. I use Blue Loctight on the bolt threads. I have several thousand miles on my carrier with this mounting without any problems. Makes mounting and removing the carrier a lot easier.
