Oxygen and Acetylene
Fowler
◇BUILD IT BOB◇
Sep 15, 2014
1,116
1,684
Moneta, VA
Bob
I just picked up new tanks
I transported them laying down
I know that I have to leave them standing up and that is not an issue they will be standing up for days before I use them
But why do I need to let them stand?
SAFETY
The tanks need to stand so they won't become projectiles, if they roll away and the valve gets broken or sheared. They should be standing and strapped to something solid if not placed in a cart. The o2 is high pressure, the acetylene tank is filled with a foam/sponge like material. Laying the acetylene on its side, some of the foam my float into your valve clogging it, making fora hard time to get a consisant flame. I'm sure you can view some videos on you tube with tanks going through the roof, or though block walls...
I knew about not leaving them lay down due to the danger but I did not know about the foam.
So the foam needs time to settle
I used a Perco Acetylene/Air for gold and silver.....And for Platinum Acetylene/Oxygen...
One time i was adjusting the acetylene flame, When the whole gauge came off in my hand, 300 PSI in the tank at the time, The tank lit up dropped and spun around on my shop floor like a supercharged roulette wheel melting and burning everything the flame hit...I got the fire out with my fire extinguishers....But it took days of cleanup cause the acetylene left black soot and black cobwebs floor to ceiling ....
Moral before you light a torch make sure all the connections are tight and the tank is securely chained to something ....:blush:....
Acetylene will self-combust (explode) when subjected to sudden decompression especially into air. That is one of the reasons for the filler material inside the tank. The material slows the expansion to help limit the combustion rate. Apparently Acetylene will explode inside the tank under the right conditions! :xzqxz: Hence the filler.
Here's some info about the chemistry: https://www.rexarc.com/blog/importance-acetoning-dissolving-acetylene-acetone/
I've never had to wait but I don't gas weld much anymore. One thing about Acetylene, it becomes unstable over 15 psi if it isn't in a stabilizing compound like the foam. That's how you go carbide fishing.
Dieseluladstron
