NTF longer clutch and brake cables for bigger handlebars...
Need To Find: Longer Hyd Clutch and Brake Cables for my Carlini 'Evil Ape' handlebars...
Havn't had any luck yet... My Dealer was no help, contacted JP Cycle, Dennis Kirk, & Drag Spec. ... No one has been able to help. Any ideas?
Stock Numbers: Hyd Clutch Cable 37200084 and Brake line 41800343
Stock Bars on FLRT are 12", and my 'Evil Ape' bars are 17", so looking for +5" or +6"
Any ideas and thoughts are appreciated. Thanks everybody!
When I put my taller bars on, I found the clutch line at LA Choppers. They did not have the brake line at the time. They may now.
I took the stock brake line...it is sort of a weird set up with the linked brakes...to a local shop that builds hydraulic lines and they modified the stock one to a longer length.
WOW, When I put the 16" apes on my Springer I ordered clutch and break hoses from JP Cycles. Had choices of regular rubber, stainless braided, and plastic covered stainless. That was a way back, but people are still adding apes to their bikes, amazed they aren't still available
Good Luck
Stitch61
