Not triker but
We're glad to have you here, keyman :). You don't have to be a trike rider to join, and if you are helping a trike owner....well, you came to the right place! We've got a number of Stallion owners here. Give them a chance to read your question and the replies will start coming in. :)
You posted here as a new member, which is exactly right, but I suggest you go to the Stallion section and post your specific question there as well; it will be seen and replied to a bit more quickly by the other Stallion owners.
WELCOME to TRIKE TALK...Yep, Trike Ownership not required...like Nana said, post Your questions in the Stallion Forum.....ThumbUp
Welcome to Trike Talk from SE Missouri. To start with on the Stallion are you talking about the main light up front or the two on the sides? If you are talking about the two on the side when you turn the light switch clockwise then you pull the knob out to turn these lights on. You will need to add the 12V outlets if you want them. You can pick these up at any part store.
While you are working on the 12V outlets, go ahead and put in a trickle charge hookup, and the leads to jump start. Only way to get to the battery is to remove a tire, Look at the Stallion Modifications page, it has pictures and great suggestions.
Welcome aboard I sent you a PM on how to contact me for help. I'm right up the street.
mudrock
