Not to minor I hope
Oct 22, 2012
327
17
Marietta, GA
Iboos
I got caught in a rain storm last week end on my 2013 T/G for about 30 min's, when I got it back in the garage and was wiping off some of the water I noticed that the frt. fender tip amber light lens had a lot of moisture and drops on the inside of the lens, it took 3 days for it to dry up, has any one else had this problem ? did you try and seal it your self, or did you take it back to the dealer ?
is this a normal thing on H/D ?
It seems like such a minor thing, but,I sure don't want any elect. problems from water in the frt. light socket.
Thanks for any advice.
So, it's normal for the nose light lens to hold moisture after a rain ?
I am going to try the dielectric grease you suggest, Thanks.
since the amber cover is not really sealed and the wire for the light is on the inside of the fender and you were driving in the rain mosture will build up. Dielectric grease will help with the corrosion of the bulb socket and causing the bulb to fail sooner.
Most do not mess with the fender light except to change the bulb..
GladisGree
