no tail or brake lights..
Oct 19, 2014
943
662
Rochester, NH
Dennis
Well I started to install the LED lights on my trike. I put on a couple strands and then decided test the "brake mode" feature. With this feature, no matter what color the LED lights are or what kind of sequence you are running, once you use your brakes, ALL the LEDs turn red until you release the brakes and then they return to the setting that was running.
Well I hit my brakes and the lights continue running in sequence and I notice I no longer have tail or brake lights. Didn't have time to troubleshoot but I'm thinking it's a fuse since everything else is working normal.
I hope to finish up the install of the LEDs today and then work on the rear light issue.
to be continued....
dhinzman1
