No stop lights
Nov 22, 2016
245
133
Groesbeck, TX
James
Neither one of my brake lights come on using hand or foot. Ipulled both rear bulbs and am not getting juice to the brake light pin. Any ideas?
check the fuses and look for a bare wire good starting point good luck Fred
  • Like
Reactions: MDO
Are the running lights operating? Also, please update your profile...It's hard for someone to help you when they don't know what your riding.:Shrug:
I had work done on mine and had the BCM changed out then found out that the BCMs are set up for two wheel bikes and there are several setting that have to be changed for Trikes
Reverse and brake lights are a couple of them.
The dealer recognized the reverse issue right off the bat but I rode it for a couple days before I notice the brake lights not working (tour pack brake light worked) and my spare key FOB would not work.
Had to take it back in.
I also believe that the green light on the Tach for the auxiliary lights is controlled by another setting as it hasn't been on since I had the work done but since the switch has a light on it I like it better that way.
I'm not suggesting that this is your problem, but just to illustrate how funky fuses can be: I have a 2018 and on a trip back from the shop my aux headlights and tour pack trim lights stopped working. I went over that motorcycle from top to bottom before I discovered that the battery tender pigtail fuse was blown. I replaced that fuse and everything works again. Magic!
I need to check the tender fuse, thanks mine is a 2016. Installed the rear LEDS, they bright, run works and so does turn signals but no 4 way flashers or brake lites either front lever or foot pedal. When I ran the codes it came back rear brake light switch and BCM. Bought the switch then figured out there's no way my old azz can change it, shop bound. Going to install my LRS 13" flat top today, I think I'am going to like it.
shawn.s.prescher
