No power, in reverse
it would be interesting to know how big of a ground wire you used.
I would seriously repair the original ground wire before riding to far.
if you used to thin of a wire and everything is going threw that wire for ground you will melt and burn that wire creating more problems than you have now. cause everything that wire is running along side of new ground wire will melt right with it.
I'm hoping you used something about the same size as the ground cable. that's on the battery now.
the ground coming off the battery should go down and bolt to the back of the engine..
if you remove and clean the ground cable on the back of the engine, clean the surface areas then put it back on that should be your issue right there.
I learned something new today from this and will remember it.
Thank you.
Thats the power of forums , Hundreds of people willing to help one another with a problem, Passing on ideas ... And eventually the problem is solved , Ready to be passed on again..ThumbUp
I'm going to parts store later today to get an automotive ground strap to replace what I used. Haven't ride anywhere yet been raining so far all day.
dhinzman1
