New Roadsmith 2012 1800
Picked the new Roadsmith 2012 1800 up yesterday and our weather went south, is it hard to set the battery up for charger. Would like to have pigtail for easy acess, is it harder to get to the battery after the trike kit is installed.
No it isn't.............just remove the side cover of the motorcycle an there is the battery........no trike parts need to removed
Hisst
Easy setup! Go to your local auto store and get an SAE connecter with wire long enough to reach from your battery to wherever you want the power source to be. Mine is located to come out from behind the passenger backrest. My battery minder plugs right in.
Sounds like a good idea. I have my SAE connector jammed in just behind the cover so the connector can be retrieved with two fingers. The pig tail can easily get lost in there.
FlintM
