New passing lamps interfere with audio
Fearless
Gone But Not Forgotten
Dec 10, 2013
7,718
4,270
Clarion, PA
Fred Foster
New LED passing lamps are great but can't hear the radio with them turned on help is there a fix? Puzzled? Fred
Had same problem when I got and installed LED headlight on my TG. Original one caused the static. Returned it and company replaced it with same type light but plug in noise cancelling filter that goes in line with power plug. That lasted a year. When it went, I did a little research and found people were wrapping an aluminum foil layer on back of light to block the noise. That helped quite a bit. I also managed to find another noise filter on line. Before my current trip, I swapped out the aluminum foil for lead tape. No real difference between the two. I just thought it might block the electro magnetic a little better.
To summarize, try aluminum foil first. It’s cheap.
bk65
