New member from Linville NC and Salt Springs Fl
Feb 18, 2017
Linville NC USA
Hello Forum, I have a 2008 wing with a 2010 Motor Trike kit installed, Taking it in to the Motor Trike dealer here in Ocala Fl on Wed's to have the rear pinion seal replaced Has any one had a problem with a leaking pinion seal? mines dripping pretty good, Also thinking about changing the drive shaft out to Motor Trikes newer upgrade, Would I notice a difference?
Welcome To Trike-Talk, There is a lot of info on your problem, And I'm sure someone will chime on soon with all the help you'll need... In the mean time do a Search..
Pinion seal failure usualy the result of bearing failure. Have them check it also.
From what I've been reading, motor Trike shafts are the way to go.
Welcome.
Dragon warrior
