new goodie for trike....
Aug 9, 2011
84
24
Baltimore, Maryland
Dave
I just installed the new harness that allows the spots to be on when the high beam in on. Harley part #69200441 This lets you run all the lights at once. When you hit your high beam...your spots stay on. with the new LED lights I had put on, it's a lot of light to be tossing down the road. Can you see me NOW!:D It was not hard to put in, just took off the outer shell and its up under the radio on the clutch side. It may not be the same with all bikes, mine is an '01 Ultra.
See ya on the road,
:wave4:
See ya on the road,
:wave4:
Congrats. That's a nice mod. Wanted to give you a heads up. With this mod, the passing lights stay on now with the ignition switch in the accessory position.
TheBobs that sux, any way around this?
Turn off the passing lights at the switch on the dash. Then you can still run the radio or whatever. But you will just need to remember to turn them back on at the switch before you start riding again.
Just mention to someone that it would be nice for spots to stay on with high beam, only problem in Virgina it will not pass State inspection like that. I did note the part number though!:)
The plug goes in OR comes out in about 15 minutes ;)
dyno56ca
