New Front Tire - Handle Bar Vibrations at 70 mph
Oct 4, 2012
31
2
Arkansas
RCflier
I have a new BattleAX BT-45 on my Honda Trike (less than 300 miles on it). Getting handlebar vibrations at about 70. Would Dyna Beads help get rid of the vibrations?
Any hints would help, besides don't go over 70 lol
YES !!!
Can I say that any stronger? Put three ounces of Dyna Beads in and I'm betting you will smooth right out. :xszpv: :xszpv:
I got that vibration at 70 with the tire mounted backwards ( with beads installed ) turned the tire around and the vibration went away ( with beads )
Has anyone else noticed a vibration when mounting the tire backwards!
I once had a regular front tire mounted while on a trip. The installer did not line up the dot on the tire with the valve stem, and it shook so bad I could not go over 65 mph. So when I got home !400 miles later I took the tire off and alined the dot to stem. On the test ride I got the bike past 105 with no problem. Hope this may help ,good luck.
Cline
