need specs on TOOLD-07 "spacer"
Status
Not open for further replies.
so i can make the socket mysely. thanks lb
I'm assuming your talking about the socket for removing the nut for the transmission sprocket. Here are some pics, I don't have it handy right now to measure.
There is a round support which screws onto the output shaft to keep from having the socket pop off and damage stuff. There is a lot of torque applied to both remove & install this nut so the tool has to be up to the task. If you don't want to make one you can get one from Georges Garage.
This is the socket and support.
This is the socket & support installed.
Status
KRC
