need help with rake installation
Mar 4, 2013
49
2
waynesboro, va
OK,,I decided to do the rake kit myself, I read what was available on several forums and felt pretty confident I could handle the job. Now, my Honda is an 07' gold wing, so I bought a manual just in case. I start the job following the procedures I had downloaded from several Honda sites. All went well until I removed the top triple tree bridge nut and started to lift off the top bridge. It is hitting a part that I have not seen in any manual or other instructions.It is a forked brace right under the ignition switch. I have included a photo I hope to shed some light. <a href="http://www.triketalk.com/forum/attachment.php?attachmentid=8060" title="Name:
Size: ">Attachment 8060</a> It looks to me as more covers(gas tank,etc.) need to be removed. Someone tell me its not necessary and the solution is quite simple
On either side of the ignition mount is a bolt that must be removed so the mount and this part that is in your way can be moved. Yes the manual doesn't mention it because they use the non-NIVI model to do their manual. The larger meter assembly dictates the need to remove this mount.<br />
<br />
I suggest you get a magnet up close to that bolt as you pull it up. If you drop it I doubt if you will get it back easily.
<div class="bbcode_quote">
<div class="quote_container">
<div class="bbcode_postedby">
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Gold Rush</strong>
<a href="showthread.php?p=167249#post167249" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">On either side of the ignition mount is a bolt that must be removed so the mount and this part that is in your way can be moved. Yes the manual doesn't mention it because they use the non-NIVI model to do their manual. The larger meter assembly dictates the need to remove this mount.<br />
<br />
I suggest you get a magnet up close to that bolt as you pull it up. If you drop it I doubt if you will get it back easily.</div>
</div>
</div>
</div>YES...!!!.....I helped a Mechanic at my Honda Dealer on one of these...<b>FOR SURE HANG ONTO THAT BOLT</b>, or You may have the same fate my Mechanic Buddy did when He let it drop.....took more "dismantling" to retrieve it.....<img src="images/smilies/thumbup.gif" border="0" alt="" title="ThumbUp" class="inlineimg" />
Okay thanks for the inf0, I was hoping to avoid any more dismantling but I had to get at those bolts. Didn't drop the bolt but did drop a 8mm socket but I got that damn top triple tree bracket off. It seems there is always a bolt or screw that ends up taking 2-3 times the time needed and leaves one to strong cussing. Please stick close as I'm sure I may need you again.. Thanks again
2011Spyder*
