Trans is starting to slip and would like to get a flyer for interstate. I pull a camper weight is about 600lb and I have a 1641. Any advice?
What do you mean by slip
Is it an automatic? If so, there is not as many gearing options.
If a standard and slip then that is the clutch not the trans.
If a standard and jumping out of gear then it might be time. Check all the shift linkage for wear and adjustment. Make absolutely sure the nose cone bushing and hockey stick are good and not bent.
Do you need a freeway flyer?
Not necessarily. What do you have now?
If it is an early swing then yes you probably need more gear. They were geared lower for the smaller engines.
A later model 4.125 ring and pinion (stock) and a tall tire get the job done with a mild engine.
There are several different gear combos called a freeway flyer.
The two most common.
A stock 4.12 gears with a different 4th gear (.82) . Drives the same except a little less engine rpm in 4th at highway speed.
Then one with stock 4th gear but a final gear at 3.88 All the gearing drives bigger.
I run a lot of gear, but I have a lot of motor and don't pull a trailer.
