Navigation Volume
Feb 29, 2012
64
12
Lake Placid Fl.
Hey Guys..
I have a 2015 Tri-Glide and am just learning the set-ups......I can't seem to find where to make the thing speak to me...I don't use the headset but want the nav system to tell me when a turn is coming up !! And what about volume ?? I'd like it at least as loud as the radio .....Thanks for the help,,,Dave
Hey Guys..
Took me a while to learn the above...if you have it set up to navigate, in the upper right corner should be "Repeat", if you toggle over to that it will give you current audio instructions.
Also, the same volume toggle you use for the stereo controls the volume of the navigation...but ONLY when it is talking. So if you hit the repeat so it will talk, then while it is talking, increase the volume the same way you would for the stereo.
Thanks Kevin...I will give that a try in the morning.......Why didn't HD just make it like a Garmin ??? It seems to me to be an overly complicated system.....Maybe I'm just too old school ?? Anyway,,Thanks !!! Dave
Hey, you're new school compared to me. I had never used a GPS system prior to what came on the bike....and it was several months after I had the bike before I used it for the first time.
Now I love it...makes things much easier on trips. But I have nothing to compare it to other than paper maps & google map print-outs. :laugh:
I had not used anything before either...Wifey always had the Garmin and it LOOKS easy..I still like my 1993 FLHS..I got it new and its all I've ridden before a month ago when we got the trike with all the fancy do-dads..
But I like it and still am getting used to it...............Dave
It Talks !!!!
Thanks a bunch....I did what you said and it works.................
HLG
