My Pro's and Con's for choosing Goldwing Trike vs TriGlide
Jan 10, 2014
185
90
Leander, TX
Jim
When I was in the process of looking for a trike, I was looking at the Harley TriGlide and the Goldwing trike. It turned out to be a fairly easy decision for me. I wanted something that would last into my old age, and give me many miles of trouble free riding. Here is some of what I put together. I loved both trikes.
Goldwing Trike
Pros:
Adjustable Air Ride Suspension Standard
Independent Rear Suspension Standard
Heated Seats, Heated Grips Standard
Smooth 6 Cylinder, rock solid engine
Reliable
3 year Warranty on bike.
3 year Warranty on conversion
Lot of storage
Shaft drive
Trailer hitch standard
Regular unleaded fuel.
Cons:
Footpegs, one riding position
GPS not standard, but can get one with built in GPS, but very expensive.
Trike is a conversion
Harley Tri Glide
Pros:
Technology, GPS, MP3, Blue tooth, Boom Box great sound
Love the footboards, changing riding position.
Lots of storage
Tons of dealerships, everywhere.
Cons:
2 year Warranty
$495 check or first 500 miles-my dealer
$495 for 1000 mile check-my dealer
Straight axel belt drive, short wheelbase
Just the heads water cooled, can get hot is traffic
Hand pump air suspension and pump does not come with it.
Low, would need a lift kit to not drag pipes.
No trailer hitch
Cost of ownership will be high
Premium fuel only
Re: My Pro's and Con's for choosing Goldwing Trike vs TriGlide
Another item that may be added. I know 3 friends that bought Triglides and all of them have had to spend thousands of dollars to increase the performance of the engine since the Triglide is under powered.
Also, brake life seems to be much shorter. At least from what I'm learning.
Two of the things that sold me on my wing. When I was driving in the Rockies and not worrying about having the horsepower going up the mountains with the Wings fuel injection especially towing a trailer. Second when I drove to California and getting stuck in downtown Vegas in !09 temps. And when I drove across the Mojave and it was 113 all day. The Wing took it all with a breeze. I had a V twin before but for long distance riding I dont think its the way to go unless youre a mechanic and rider.
Marketing 101. Sell a $30,000 product and then charge another 5 to 10 thousand to upgrade it to what it should have been to begin with.
When I was looking last October I test rode a lot of trikes.
I really like the comfort of the tri glide, we ride a street glide most of the time. However I rode a conversion from a 2 wheeler to a trike now that was really impressive. Almost bought it. Test rode 3 goldwing trikes, different kits.
That ended my search.
For a trike the GW is a great plat form to start with.
Thought of triking the cvo street glide but to get it like I wanted it would have came close to just buying one out right so that's what I did.
You did good grasshopper.
I actually did not test ride anything. I just found what I wanted and did the deal over email. Then went up and road it 380 miles home. I did not even test ride it before I rode it home. But I am totally happy with the Goldwing Trike, I love it more every ride, and now that the weather has been in the upper 70's this past week, I still can't wipe the smile off my face. Can't wait to take a long trip on it this spring. It is so comfortable. I did add the Airhawk R, Risers, and Ergo II Highway pegs.
Your pros & cons were right on the money...as stated Harleys are underpowered for sure...Put in Stage 1 or Stage 2 ($$$$) then much better. And the heat, Oh that heat!
Exactly what I did except for riding it home due to weather. I had a HD Ultra Firefighter special and thought about triking it. I found my Goldwing CSC on the web in N. Utah with only 16K miles. Had a buyer for the Ultra and got into the Wing for about half what it would of cost just to trike the Ultra with a cheap kit.
Another thing about the Tri-glide is your stuck with a solid axle, and a very short trike. My Wing with the CSC has around a 9" longer wheelbase and independent axles.
I haven't rode a Tri-glide or any other trike, but I'd like to try one with the shorter wheelbase just to see how they handle.
Now, with all that said, I need to ride tomorrow... it's suppose to hit 62F in this part of Utah tomorrow.
You mention as a 'con' the - tri-glide needs premium fuel. Does this mean you are putting regular in your 1800 ? :confused:
Not the OP but, yes, you should be using regular in the 1800. Reg. is actually better for it than premium.
Also, the OP listed a 3yr warranty on the bike as a pro. Hope he doesn't have a drive train failure that can be blamed on the conversion!!!:Meds
Anyone who puts premium fuel in a GL 1800 or any other Goldwing is wasting their money. It does nothing to increase performance, does not help it run better, and only costs more. There have many several threads on this subject over the years and every chemical engineer, honda rep, or article on this subject has concurred.
I always fill my 2012 Wing with regular, big difference between a 6 cylinder liquid cooled engine vs a twin cylinder air cooled engine.
Ya know I read thru this post with a lot of remarks to myself.
1st, I'm a die hard Harley fan so I am a little bias. Have been riding for 60+ years and have owned or ridden just about every flavor bike you can name. Still own, in addition to my TG, a couple restored Honda XLS 350's and a Sears Moped. My first observation about Honda's vs Harley's is you ride "on" a Honda and "in" a Harley. Hope you understand what I'm trying to say.
2nd: I have a '13 TriGlide that runs just great with a high flow kit. I have added several cosmetic things but other than a tuner and exhaust, maybe $800.00, that's all I've done to the trike and it runs great. I even pull a Bushtec Roadstar trailer.
3rd: Premium gas. Never run it. I do use Mid-grade most of the time. As somebody said using premium is a waste of $$$$. Have a couple friends who work in the oil and gas industry who laugh all the time about the only people using premium gas are motorcycle riders. Also because of the lack of use the premium tanks are always dirtier.
4th: When I started developing Parkinson 2 years ago, loosing my balance control, I started looking into trike conversions because I didn't want to stop riding. I owned at that time a 2010 Harley Ultra Classic. Being somewhat over analytical I did a lot of analysis of various Harley conversions and others. I figured it was going to cost me more to convert my 2010 to a trike than to buy one. Also, utilizing KBB and NADA numbers I figured I'd loose 24-28% a year in deprecation on a conversion vs 6-9% on a new HD trike. No brainer.
I've put my kickstand down in all 48, the four furtherest most corners of our great country, the high and low, Canada and Mexico on 2 wheels. Now to do it on 3.
Over heard a factory rep at the TT get together in Eureka Spgs last year say "on a Harley you can run over a nickle in the road and tell if it's heads or tails" NOT true. I've ridden those so called IRS conversions and my opinion they're not that much better if any at all.
Okay, now which closet did I get this soap box out of. Going to go over in the corner, sit down and just watch. 8~\o
Hi Thomas, yes, I have used nothing but regular unleaded. I have no pings and it runs perfecty. If I remember correctly even the manual says 86 Octane ore higher. I think regular unleaded is 87? I have had other vehicles that the dash even had Premium fuel and I never did, just used regular unleaded.
Hi Texan, I love the TriGlide and Harley as well. Just had to make a decision that would last me a lifetime (I am already OLD). If I had unlimited funds, I would have one of them as well.
I have a 2008 Ultra Classic with a CSC trike kit. I bought the Harley
new had Had it Triked because I liked the Adversary color. I have
about 6000 miles on it after the conversion by CSC and with a $1,000 or so in upgrades to the motor I feel this is an excellent trike.
I rode a 2014 triGlide and found the performance better than my 2008 but
the CSC conversion seemed to ride and handle better.
Last Saturday I took delivery of a new 2014 Gold Wing Navi/XM converted by
CSC with their viper kit. After just a couple of hundred miles I am convinced
this a much better overall ride than my converted Harley Ultra.
The Gold Wing is more expensive but it lacks nothing except a cb which
is also an extra on the TtriGlide
In retrospect I wish I had bought Honda first. Overall it seems a much better
match to my expectations.
Now I have two trikes in the garage.
Bill
I had a 2010 Harley tri glide and put 52000 miles on it. Bought a 2013 Gl1800 Nav CSC new, I now have 34,862 miles on it. The Honda is hands down the best ride. Regular gas for the Honda. We went to Alaska last May 11520 miles and no problems. I can't say that about the Harley.
I think it would be interesting to see this same conversation on the Harley forum.:Coffee::Coffee:
I am a member of both forums and I don't believe the discussion would be significantly different.
The GW is the superior trike platform, hands down - power, comfort, ride, handling, braking, mileage - you name it.
Don't misunderstand. I love Harley's and have owned several. Currently I have a 2002 Lorider and a 2014 Ultra Limited. The limited is magnificent - much more fun to ride, great GPS and sound system and the Lowrider is a biker's bike.
U
That being said, the 1800 is the ultimate touring bike for two folks, hands down.
I think it would be interesting to see this same conversation on the Harley forum.:Coffee::Coffee:[/QUOTE
U
Be careful about posting anything positive about a Goldwing on the Harley site. Especially if it compares the two in any way. The readers there will flame anyone who posts anything negative about Harley, whether it is accurate or not. I stopped posting anything on that site, ( and I've owned 7 Ultras in 20 yrs) because every time I posted anything that Harley readers objected to they were brutal and got personal. One guy even suggested that Wing riders shouldn't even be reading "their page".
I'm a member of this and three other HD forums. I don't see this discussion taking place on a "Harley" board. Bazooka and I had this very conversation in Eureka Spgs this past June at the get-together. How he was told that a board of this kind would never work. Harley and Honda or what ever riders could never sit around the same campfire. Proved 'em wrong.
I will say though there are some that get their shorts on a little crooked at times and I'd bet they are not on this board. A GW jumped into and rode in the Harley 100th Anniversary parade in Milw in 2003. I mentioned this to a good friend that has a GW and said I wanted to go ride (although I wouldnt) in a "National Wing-Ding" parade. He said it'd be stoned to death..
This forum is good in that we can sit around the same campfire and have civil conversations BUT if somebody starts singing "Kumbaya" I'm out of here. LoL !!
8~\o
I know I have said this a million times.....You just can't beat the SOUND and FEEL of a Harley trike going down the road. It just makes me feel COOL !! but I will say that the GW does ride smoother...:gah:
:Agree: All the bikes I had over the years always gave me a smile..
But every time got on my [ex] Sportster, And my T/G It just had a sound and feel that none of the others could mach...
It's called an Intangible; [Something Inpossible to define..] ThumbUp
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed." - Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
If all riders adopted this philosophy all rides would be utopian.
G.Wing is: A lot less expensive to maintain. Harley dealer maint, costs, oil changes, etc. are absolutely
ridiculous. (and Harley's are high maintenance bikes).
DEPENDABLE. It is very rare to see a Goldwing (or any Honda) broke down alongside the road.
SMOOTHER RIDING: There is NO VIBRATION at all on the Goldwing. V-Twins are the worst.
I asked a Goldwing rider in Daytona why he was wearing a Harley jacket. His wife said " we have both. when I go we take the Honda, when he rides alone, he takes the Harley. Harley's are Uncomfortable.
A Goldwing rider can ride longer and more comfortably that a Harley rider.
A Goldwing can last 500,000 miles, and a lot of them have (and with minimum maintenance). How many Harleys can do that> (probably zero to none!)
Oh yeah, up until 2012 Goldwings were Made in America.
I guess I could go on & on, but you get the point: Harley's are Overpriced, Overrated and Not reliable.
8~\o
I like both and have owned dozens of bikes and trikes over the years of various brands, but most have been either Harley or Honda and I'm back on a Harley now after several years on Gold Wings. I have to agree that yes, the "cool" factor of Harleys is a big part of the appeal and for some unknown reason, seems to ramp up testosterone levels in most human males, a real piss-n-vinegar generator.
I've found it interesting that percentage-wise, Harley owners are much more likely to earn themselves a trip to banned camp by pushing things to the limit and beyond. I hate to ban anyone, but I learned early on that if I didnt keep a handle on things, this place would have melted down years ago.
AND, hot as hell to ride in the Summer. ( I know, I had 7 of them)
I have noticed that a lot of guys own a Goldwing Trike and a Harley bike. That's the best possible scenario, one of each, but I plan on having a Harley trike and a Gold Wing bike.
Jester61
