Motortrike reverse failed
Apr 9, 2023
2
Box Elder, SD
Lester
Hi there. I have a 2016 indian roadmaster with the motortrike conversion. I went to back it out of my garage this afternoon and the reverse is not kicking in. The power button lights up but when I push the start and horn buttons nothing happens. Is there a manual I can get to look into this issue?
Lester, Sorry I can’t help you on your reversed problem but I can welcome you to Trike Talk👍👍..
Hi there. I have a 2016 Indian roadmaster with the motor trike conversion. I went to back it out of my garage this afternoon and the reverse is not kicking in. The power button lights up but when I push the start and horn buttons nothing happens. Is there a manual I can get to look into this issue?
Lester, the problem you will be encountering is not many members have that Motor Trike setup. May I suggest that you contact Motor Trike direct for advice. I expect the reverse is different then the one they sell for the Harley. Welcome and good luck.
HLG
