Motor Trike Vibration/Rattle
Status
Not open for further replies.
Jan 3, 2009
1,879
61
United States
Dave
Kept hearing a rattle as I would drive down the road or crack the throttle from a red light. You may hear it if you turn off the radio but it is a distinctive fiberglass rattle.
Was looking around today and found it. You guys with Ultra conversions may want to take a quick check at this.
The top of the trike fiberglass body, just under the tour pack, has a rounded edge on both the right and left had sides. The rounded part of the lip is an "L" that is turned upside down.
The lip under the tour pack looks like this from the side.
(front of the trike) -----\____/----------- (rear)
The dip is an opening for a wrench.
The left or front lip was rubbing the bottom of the tour pack. It has rubbed through the paint and was digging into the fiberglass of the tour pack and wearing down the trike body.
I took a piece of fuel hose, cut off two 1" pieces and split them to make a cushion of sorts for the lip.
Take the seat off so you can get to the 4 nuts that hold the tour pack on. (There are 5 nuts total but there is no need to loosen the rear bolt. Remove the tour pack liner to get to the heads of the bolts. Just loosen them until you can move the tour back. Both the bolt heads and nuts are 7/16th.
Take the cushions and slide them from the front to the back starting just under the tour pack speakers. Lift the tour pack and leave the cushion to where the tour pack will sit on it. Do this to both sides.
Tighten the 4 tour pack bolts, reinstall the liner, put the seat back on and your done. The tension of the tour pack should hold the cushions and stop the rattle.
Hope this helps.
Great resolution to a problem that most would not have caught. I' m checking my Champion in the morning. Most of these conversions are very similar in the mounting areas. Thanks, Ted
Status
Gray_Ninja
